Machete Mods Tutorial Video
Machete Modifications Tutorial Part One
Machete Modifications Tutorial Part Two
A few years ago I realized that I hated new machetes and much preferred my old worn out ones. I sat down and took a good hard look at my blades to figure out why and discovered that I had been transforming the blades to have a high, flat, sharp edge at the base and a robust convex forward of that. I also had squared off the spine of the machete to make tinder shavings and rounded off the forward portion of the spine because it was tearing up my hand. Ever since I started modifying my new machetes to that configuration from the start I never looked back. This is the process I put my new machetes through, feel free to use it if you think it would work for you.
A little over a year ago I posted my first machete modification video. Since then I have had numerous requests as to how I put the modifications on the blades and how I sharpen a machete. The first part of this two part video shows how to take a new Tramontina 16 inch machete and do the basic file work necessary to put a scandi edge at the base of the blade, convex the forward portion, and create both square and round sections on the spine.
The only tools needed for these mods are a large single cut mill file, two "C" clamps, sandpaper and a work bench. Of course the actual process takes much longer than the video, I eliminated much of the repetitive filing from the video but left in all the steps of the process.
Safety Warning: You do this at your own risk. The process demonstrated involves filing a machete blade towards the edge. That is inherently dangerous, as are machetes, files, and workshops in general. Never leave a machete blade clamped to the edge of a workbench, you run the risk of someone bumping into it. Whenever you stop working, remove the blade from the clamp and place it in a safe location.
The second video (I'll upload it later this week) shows how I correct the grinds and sharpen using a Smith's Tri-Hone. I have found this simple sharpening system to be very useful. The final result is a machete that is sharp along its entire length and gives me a variety of edges to work with in the bush. It is also an edge that I can maintain simply in the bush with a small diamond rod.
Mac
Excellent video Pict, thanks for posting this as it is very informative.
These are the types of videos that I suggested should be in a dedicated "Wilderness Skills and Tutorials" sticky.
I'm in the process of making the Nicholson/Collins machetes I just picked up serviceable (came with a 1mm thick "edge!"), so I may very well do just this! ;)
Pict - Very informative. I modded a couple of my Trams based on your photo presentation a while back, now I'm going to try another based on these vids! Thank you.
Great video. Thanks for the lesson on fine tuning a mechete towards our own preference. After seeing that I feel much more confident that I can run through mine and tweak it for my own needs.
What a great video! I thought I was doing great by convexing the edge as I always had for years.
Your video makes the machete twice (or more!) useful than a just being a sharp knife.
I particularly like the squaring off of the spine. With the back sharpened like a cabinet scraper, it would be really easy to roll off wood curlies for tinder.
Nice job!
Robert
very nice video mac.
I did those mods some time ago on one of my machetes, following your suggestions on the old video you posted.
this one it's a nice complement to the older one.
thanks!!
Great vids Mac, now I'll have to replace the saw backed Ontario and give modding one a shot.
Great video. I googled a 16" Tramontina and didn't see one. 14" or 18" is all I can find in that size range. Not available in the US perhaps?
You don't want a really long machete for bushcraft use. I don't do these mods on anything longer than 16 inches. Good candidates for this type of machete are the 12 inch Ontario, 14 inch Tramontina Bolo, and the 12 - 16 inch Latin pattern. Of course other quality brands of similar dimensions would work fine too. It doesn't make much sense to put these mods on a 22 inch heavy machete, it would be awkward to use them. Anything over 16 inches gets a full length convex for me. Mac
Pict, Great mods. I'll be in the garage tomorrow to give them a try. By the way, I watched a bunch of your videos this morning and they are great. I love the truckers knot demo. Thanks for sharing your extensive experience and knowledge.
