Machete sheath {cheap!}
I made a machete sheath that may interest some of you. Jeff Randall [who,I assume, has had a machete in his hand more than I will in 5 lifetimes] says he uses duct tape on the edge until he hits the field then goes without a sheath. I canoe trip and I wanted some sort of sheath to carry my machete. I'm sure my machete is carried a larger % of the time and used a lot less than Jeff uses his.
I cut 2 4"x [length of blade] strips out of a worn out Rubbermaid trash can. I put solid rivets around the perimeter [of 3 sides obviously.] I drilled a few extra holes and tied loops of paracord through them. Voila, a machete sheath that can be clipped or lashed to anything. It isn't a belt hanger [unless you use a biner as a frog] but that isnt' my primary carry mode. Mine is strapped to a backapck or binered to other gear in my boat. Most machetes don't come with a sheath and I'm sure that in the tropics my sheath would rust a blade overnight. For my use however, it's a cheap and protective solution. I love big blades and thought this may help someone.
Hi B-
That brings up something I've been thinking about for a while. I have a black rubbermaid trash can that looks and feels alot like Kydex (but a little thinner). Does anyone know what kind of plastic Kydex is? (polythelyne/propylene/nylon/etc)
I've also used those plastic roll up tobbogans as reinforcement and stiifenning on various outdoor items- I guess it could be used for that type of sheath also.
JB
boyscout -
Kydex is a blend of acrylic and PVC. It is available in various thicknesses, 9 grades and over 200 colors. It has excellent thermoforming capabilities and is best formed in the temperature range of 325 to 390 degrees.
If you have any specific questions, I'll try to help. I work in an industry that uses a lot of plastics and I have access to a lot of related information.
Hi Daniel,
thanks for the info.
I tried to get Kydex locally, but none of the plastics suppliers in a 50 mile radius had even heard of it. I now have found some online suppliers(knifemaking supplies)
JB
