I don't go quite as far as Nathan, but do something similar by shifting my angle now and then. Obviously at the plunge that's not going to work, but past that I don't stick to the exact same position every stroke.
I also jump from 36 grit to 60 then 120 fairly fast. 36 grit gets me down to "ok, it's got a bevel mostly flat and mostly up the blade, I've got 75% of the metal removed." 60 flattens that out and gets me into the actual ballpark for the bevel height but still some actual metal to be removed, I'm not worried about exact grind height or edge thickness yet, just that things are consistent. 120 is where I start making it look like it will be when it is done. Bevels get ground to almost the height I have in mind, edge thickness should be right about there too. If they aren't coming together properly I make my adjustment here. By that point there's no way there are any scratches bigger than 120 grit and I have enough metal left to remove that they're going to go away too. I switch to 220 to finalize the bevels positioning and from there it's "finish" where I run through progressively finer belts till I'm wherever I plan to start handwork or leave it as is. I do mostly belt finish or scotchbrite finishes these days anyway.
The key for me is that each step removes enough metal that I'm not worried about scratches, I'm still removing significant metal right until I hit 320 or 400 grit. The amount of metal is less and less, but so is the potential scratch size I'd have to worry about. Also, mistake size, which is how I got into this routine. I never want to be in the position where one extra pass, or a bit too much pressure on that pass can over run where I want to finish. I would rather make three our four extra passes with the next finer belt than risk screwing up the knife by over grinding.
