Machine screws identical to the 2011 CS Voyager clip screws?
I just got a 2011 Cold Steel Voyager XL, and I absolutely love it. Unfortunately, however, it only comes with enough screws to attach one pocket clip at a time. On big Cold Steel folders like this, I like to attach the left and right clips simultaneously.
So, if I order screws form a big supplier like McMaster Carr, what exactly do I order to fit in the threaded oles on the Voyager and look identical to the screws already there?
If necessary, I can just replace all the clip screws with new ones, but I still need to know the size and pitch of the ones it comes with.
I don't have a CS Voyager XL, but judging from some pictures they look like button head torx.
Make sure you check the thread size with a pitch guage, just in case they are metric. I'd buy them longer than you need, then trim them down. It's harder to do it the other way around.
Ric
It will be tough to get them right without a way to check the pitch and size. At work I use taps, also have 2 racks of mounted nuts and bolts to check the larger sizes. You could buy a cheap tap and die set from Harbor freight, always handy to have around.
