- Mar 19, 2007
I quickly made this prototype the other day as a top bearing for a Bow Drill. My thoughts are that I would like to make these with more care - properly countersunk screws, and a brass or aluminum tube for a lanyard or a length of cordage that you could use for the bow itself.
The aluminum is 1/4" thick and the dimple is a little under 1/8th thick. The aluminum does get warm when used as a top bearing - but the wood absorbs the heat a dissapates it before it gets to your hand.
The bearing itself is 2 1/4" Oval and 3/4" Thick.
My thinking is if you had this in your kit with a length of cordage (perhaps made into a cobra stitch as a sort of fob, you would always have a really efficient way to make bow drill fire and cordage.
I know that there are some marring on the aluminum (I dropped the bar after milling it - dang it) and I know the lanyard hole is a little too close to the edge - it didn't start out that way - but it was a little too large so I cut it down... anyway...
What are your thoughts?
TF
TF
