So I am finally going to make my first complete knife from a piece of steel. I am unsure of what type of steel it is. I have plenty of it to waste, so that’s what I will be using. It is most likely 1018 cold rolled. But I am not really sure. Bought it many years back for another project that never actually happened.
I modeled the blade I will be making, refer to image. For reference the overall length is 10.00” and the width of the actual blade portion is 1.125”. This will be .500” thick.
For this first knife build, I will NOT be using a belt sander. I will be machining the entire knife on my manual mill. Including the cutting edge. Mainly because I do not have a belt sander. It’s on the “NEED” list.
Few questions…
If the material I have is 1018, which is not ideal of course. Is it worth heat treating the blade after all the machining has been finished? Or leave it as is?
To sharpen the edge, will machining the angle in leave a nice enough edge, or will some type of hand work be needed to get a clean sharp edge. If so, what method would be best to get a sharp edge?
This knife will be used for general hacking and is really just practice for myself. Is their a coating that would help prevent rust and extend the edge that is easily applied at home?
Few questions…
