I'm honestly not sure what cutting tasks a machinist runs into on a day-to-day basis, so I'll categorize my recommendations and stay within the brands you've already mentioned.
If you do a lot of cutting of light materials (paper, thin plastics) but precision cuts are not the priority, I would go for a Maxamet Manix LW as it will retain a working edge for a very, very long time..
Frequent medium-resistance materials (cardboard, zip ties, plastic straps) I would suggest the Gayle Bradley almost entirely for the excellently-treated M4 that Spyderco puts out.
If you only make a handful of fine and precise cuts in a day, I would suggest the 204P Domino. Obviously, if you need to make many precise cuts, you should be using a disposable xacto knife or something of the like.
Now, here's where I deviate from the knives you listed.
If you're going to make a lot of precise light cuts, I would suggest an M4 PM2.
If you're making cuts through heavily-reinforced materials (think tires, cables, etc), I would suggest the CPM-4V Manix. The steel it exceptionally hard and tough, and will go through softer metals without much appreciable damage.
If you're making precision cuts through moderate-resistance materials (like thick rubber) I would suggest an M4 Paramilitary 2. A relatively thin full-flat grind for minimal resistance paired with a very hard steel that has high wear resistance.
All of that said, there's a lot of functional overlap between these knives. Nearly all of them can fill the roles I listed to a sufficient capacity. Overall, as long as you aren't cutting insulated cables (with what is definitely the wrong tool for the job), I would say you're good with nearly any of the knives you mentioned. If I had to pick one out as the better all-around choice, I would say it's the M4 Manix. It's a great steel, very utilitarian, with a full flat grind and a fairly intuitive and very secure lock.
Edit:
Ok so have basically narrowed it down to :
• Gayle Bradley 2
• Manix 2 KW Exclusive 52100
• PM2 52100
2/3 are FFG, and 3/3 are non-stainless high wear-resistant steels. I think a M4 Manix is probably your knife.
