MacTech's H-1 steel Corrosion resistance test
over on the Spyderco forums, both smcfalls13 and I have started corrosion tests on Spyderco's H-1 steel Salt series knives
Here's smcfalls13's thread with his test, and my thread will be posted below
As of 2:20 PM 3/25/06 MacTech's corrosion test has started....
testing chamber consists of a 2.5 gallon tank with glass lid (closed to contain salt spray)
testing fluid is 52 Oz. of fresh Atlantic Ocean seawater, collected from York Harbor Beach, Maine
spray creator is a Second Nature Whisper1 air pump and a Penn-Plax bubble-wall wand, water covers just far enough over the wand to create salt mist (and salt *foam* as well....)
testing chamber filled and sealed 2:20 PM 3/25/06
knives tested;
Buck Metro (420-J2 steel)
Sheffield Hawkbill (Generic "Stainless Steel", probably 400 series)
CCC Balisong (unknown "Rostfrei" steel, again, probably 400-series)
Spyderco Pacific Salt (H-1)
knives are leaning against the glass resting on the handles, to maximize exposure of the blades to salt spray
Questions i have....
How long will it take for the knives to show oxidation
which will be the first to rust?
will putting a *Pacific* salt in *Atlantic water cause a rift in the space-time continum and destroy the universe as we know it?....
only one way to find out.... ;)
pictures of the testing chamber and it's victim.....errr...subjects
Edit; it is now 2:50 PM, and the salt foam is getting *very* agressive, this is going to be a better test than i thought....
Observe....;
Edit #2;
3:35 PM, and i have my *first* victim......
the Sheffield hawkbill is showing signs of rust spotting around the "Sheffield Mfg" logo on the blade
a little over an hour in salt spray/foam claims the first victim
the CCC balisong is still unaffected, as are the Buck Metro and Pacific Salt
First victim fell in an *HOUR*, and just as i expected, it was the crappy Sheffield Hawkbill....
Quote "testing chamber filled and sealed 2:20 PM 3/25/05" quote
So you started this about one year ago or is that a typo?
there's now faint rust spotting on the CCC Balisong, Buck Metro and Pacific Salt remain unaffected
If you want a good test call several of the dive shops in the Florida Keys and see what dive knives are being used and how they hold up day-after-day in the salt water environment. The higher end are all H-1 steel, used by dive masters and others. That's a good test.
It would be interesting to see this test done with different lube/protectants like Tuf-Glide, Militec, WD-40, and others.
FlyingMuskrat said:
Its been 4 days....any new developments?
I've been keeping it updated on the Spyderco website, but long story short;
Sheffield Hawkbill; first spots in an hour, failure after 6 hours
CCC balisong; 24 hours to failure
Buck Metro; slight dulling of finish, salt crystal buildup on the edges of the scales, but no rust, *mostly* unaffected
Spyderco Pacific Salt; unaffected
test ended at 36 hour mark due to rust contamination of the test water
final test on Sheffield, resting the tip of the blade in Coca-Cola for 3 hours to see if it could remove rust.....
it did, Coke-treated blade area nice and shiny again
