I'm toying with a build and was seeking feedback LOL.... I'm one of those guys that constantly needs to be fiddling with something, building some weird zombie killing weapon I saw off youtube or some BS like that.... anyway, I hit on an idea.... figgered I'd ask you folks what you thought, maybe someone can think of a reason it won't work and save me the time and trouble LOL
What I'm thinking is the Cold Steel Liverpool Assassin... its a cricket bat! flat on the back side....looks like this.
and adding some of these serrated knife sections from the local tractor supply...they are about 3x3inch and hardened steel .....
now, if we combine those 2 items in ust the right way, could we not end up with a very serviceable version of one of these.... but made with much more user friendly and modern materials....
I'm thinking with the flat back on the Liverpool Assassin I should be able to stand it up on edge and ride it down the gate on my table saw, using its blade depth adjustment to cut the slot to a precise depth with use of a fine toothed blade. Once the slot is milled out, measure out and drill the mounting holes on the drill press to run bolts thru to hold the teeth in....
should work no? yes? anything you'd do different?....something I'm overlooking?.....
