- Oct 16, 1998
Well Cliff's experience with the TUSK stuck a burr under my saddle about the durability of the edges of Mad Dog Knives so I had to check it out for myself. The only Mad Dog I have around to evaluate is a Lab Rat, the skinny runt of the Mad Dog litter.
There is no question that my Lab Rat is representative of Mad Dog heat treatment. The slip sheath has polished the blade until the temper line is very conspicuous. It runs parallel to the medial line of the blade, about 3/8" from the edge. The temper line intersects with the edge where the edge turns up toward the tip, about 3/4" from the tip. The edge is definately harder than the balance of the blade. From what I remember reading, Mad Dog estimates that his blades quench out at around 63 RcH, and he then draws back the spine to something in the low to mid 50's.
So being the inquisitive sort that I am, I did a California version of Cliff's test. I drove the edge horizontally into the narrow side of an interior grade pine 2X8, using a stick as a driver. I drove it in right about to the temper line which took a fair amount of hammering. The knife was wedged in tightly. So then I started flexing the handle up and down. I would have to characterize the flexing as gentle to moderate. The Lab Rat blade is only 1/8" thick, and I know I could put a permanent bend in it if I wanted to. I would estimate that the blade was deflecting about 15 degrees from horizontal in each direction. Eventually the board's grip on the blade loosened from the flexing, and the blade would slip out. I repeated this three times.
To see if I could do something useful and stressful, I drove the blade in about 1/4" at a 45 degree down angle, then made another cut at a 45 degree up angle a few inches lower on the board. Then I pushed the blade back into the top cut and twisted out a couple of fair sized chips. The edge was not damaged or affected in any way. I could feel no lip or burr, and it still sort of shaved, I think what us sharpening geeks call "hair scraping" sharp, which is where the edge was when I started.
I do not mean this to be any sort of indication as to what happened to Cliff's knife. It was about 50 F here in San Jose this morning when I did the fooling around (too half-assed to be called a test).
So I rest assured. Mad Dog Lab Rat #007 appears to be a strong little knife. In actual use, I would not intensionally put this much lateral force on a blade this thin. Again, I don't intend to say that this resolves anything regarding the suitability of the TUSK for the use that Cliff put it too. I only mean to say that other Mad Dog owners can rest assured that their knives will not be damaged by moderate abuse if my Lab Rat is representative, which I think it is.
Harv
Harv
