My disclaimer: USE AT YOUR OWN RISK!
All I did was go do a search on the internet. I found a mad science page with the recipe.
Get some Trisodium Phosphate (TSP) from your nearest hardware store. It is used to clean grout.
Next you need some 9 volts and scrap pieces of Ti.
Mix the TSP with hot water at about 4 cups of water to 1 cup of TSP.
Hook the 9 volts together in series until you reach the desired power. This comes directly from Knifeforums. Do a search for anodizing and you will find a fact sheet containing what voltage=what color. I hooked 4 together giving me 36 volts to do the the LCC.
The only thing that can touch the solution and Ti is Ti. That is why you need scrap pieces. Hook the negative lead to a piece of Ti and leave it in the solution. Hook the positive lead to another piece of Ti. Put what ever you are going to anodize in the solution (it must also be Ti) and touch it with the positive piece only. Do not touch the negitive lead, just let it sit in the solution. The piece you are anodizing will begin to bubble and change color within seconds. Just watch it until the desired color is achieved.
When you are done, stop touching the anodized piece. Take out the negative lead also. Reach in the solution, take out the anodized piece and wash it off with some windex and rinse it with water.
Then repeat and experiment with different voltage.
