Just because it says salt, doesn’t mean they are all equal…….Yes they use Magnacut for their Salt line so it's perfectly suitable for Maritime adventures.
I've been hearing about this lately, kind of a bummer if true to have a rust proof H1 blade but then the hardware gets all corroded. Gives me less confidence to try to take my beloved Pacific Salt swimming in the ocean this summer. It's hardware is non coated, do we have any info of what materials the pivot and screws are made from?and near the hardware locations
It's easier to make the hardware more stainless that it is to make a good blade steel that won't rust.I've been hearing about this lately, kind of a bummer if true to have a rust proof H1 blade but then the hardware gets all corroded. Gives me less confidence to try to take my beloved Pacific Salt swimming in the ocean this summer. It's hardware is non coated, do we have any info of what materials the pivot and screws are made from?
He said he's trying to make the most "bad liquid to put a knife in".So which ocean is comprised of bleach, vinegar, water and saturation levels of salt? I think I want to stay well clear of that one.
Thank you for reminding me why I don't watch Youtube knife videos.
Any steel will rust if you put it in the correct environment.
Thanks for this. This is one of the more interesting posts I've read in a long time. It goes to show that there are a lot of chemical processes going on all at once, and no steel is completely immune to corrosion/rust. Living in Colorado, there's not a lot of worries for me there.+1 And many "stainless" steels are very sensitive to chlorides (like the sodium chloride -- table salt -- in seawater and sweat)...chlorides will pit many stainless steels in a hurry. (And no, you don't need to use water with "saturated" levels of salt...once seawater dries on a knife blade, it becomes hundreds of times as salty as a saturated solution...it's basically "wet salt" since salt has an affinity for water and never truly "dries" outside of a furnace.)
I do a lot of offshore fishing (tuna, billfish, etc) off Virginia and I'm not sure I've seen any "good" steel that really stands up to seawater for long...haven't messed with Magnacut yet, though.
My Buck knives take it, and they're fine for what they are, but I wouldn't consider them particularly "good" steels...If I'm out chunking for tuna with butterfish (lots of bait cutting involved) I'll just use whatever cheapo knife is around. I sure as heck wouldn't take any of my expensive knives out in that mess.
Once you start messing with seawater, there's also the issue of galvanic corrosion (dissimilar metals in an electrolyte -- which is where the fasteners can become problematic) and crevice corrosion (the crevices in SS act like little batteries, with dissimilar components of steel alloys like Fe, Cr, Ni, etc undergoing galvanic corrosion at a microscopic level due to seawater electrolyte in the crevices...and don't forget, seawater effectively contains everything) ... seawater is harsh stuff and destroys metals far faster than most people would believe. And you can get induced currents in all kinds of places where you would never expect...try trolling with wire line and spoons for kings, you might grab the reel and think you got a fistful of hot 440VAC...those stray currents -- which are always present in this kind of corrosion -- only accelerate the whole process. It almost becomes a dumpster fire feedback loop
TL;DR -- I guess what I'm saying, as a longtime saltwater fisherman, is that I don't think anything is really going to hold up. But you don't need uber steels out there. Leave the good knives at home to cut up the tuna and wahoo when you get back to the barn. And use whatever ya got at sea...and most importantly, after you get back to the barn, be sure to soak your knives, your shoes, and your wallet, in plenty of freshwater! Salt has an affinity for water, but water has just as much affinity for salt!
