Magazine article tested Multitools?
a223cat
Kuttin' Kitty!
anothre forum, someone said "Outdoor Life" did a test on Multitools and picked the LM Surge as the best overall.
anyone have this magazine? would be interested in the test!
I ran the query through some Journal Databases, and the article you are looking for was written in SEP 1997 by Monahan, Philip and was titled Tool Time. Can't get the full text for you right now, but I'm working on that. :)
Here you go:
Abstract:
Ten widely varying multi-tools, priced from $99 (Wenger SwissGrip; Gerber Multi-Lock) to the Coast Pocket Wrench ($10) are briefly described, and a table of standard and optional features is provided. The highest rating is earned by the Schrade Tough Tool ($79).
Full Text :COPYRIGHT 1997 Times Mirror Magazines, Inc.
In the beginning, there was the Leatherman. And it was good. In 1983, the Pocket Survival Tool -- created by a machinist named Tim Leatherman -- revolutionized the cutlery industry by usurping the place of the "scout knife" in the hearts of sportsmen. Soon little brown Leatherman holsters were gracing belts from Key West to Kotzebue.
But in a competitive marketplace such success does not go unchallenged for long, and the big knifemakers began chipping away at Leatherman's dominance by offering a slew of new and allegedly "improved" features. There's now a mind-numbing array of multi-tools and features aimed at every conceivable fact of the sporting world. Here's the skinny on the big names and new contenders vying for a spot on your hip.
Leatherman Super Tool
The top of the line from the company that started it all, the 1 Super Tool is a meaty hunk of stainless steel that feels solid in the palm. It's simply a bigger and better version of the original Leatherman (a name that, like Kleenex, has become the generic term for all products like it), featuring a serrated blade, a wire stripper and a ferocious saw. All parts fit snugly together and, best of all, the blades lock -- a vast improvement over the knuckle-imperiling original Leatherman. Problems that haven't been solved: It's hard to open with one hand, and, when you bear down hard on the pliers, the edges of the handles bite painfully into your palm.
Bucktool
Featuring the most ingenious folding system of the bunch, the 2 Bucktool offers several different in-use configurations. Unfortunately, this same design also makes the whole tool a bit squirrelly: The Bucktool moves a lot as you use it, and when you squeeze hard on the handles the whole thing twists uncomfortably. All the components move smoothly and lock into place, and the blades are quite sharp.
SOG Paratool
The only multi-tool named from the Latin -- parare (to prepare) -- the 3 Paratool was a direct challenge to the Leatherman. its distinguishing advantages are easy one-hand opening, smooth outside handles for gripping comfort and a plier hand that can be angled to get into tight spots. The more encompassing design does give it a slightly flimsy feel, but it is a well-crafted and ingeniously thought-out tool. The hex-bolt construction also allows you to customize the Paratool to your needs by adding optional accessories. The knives are strong, sharp and hold an edge, which makes the fact that the blades don't lock all the more surprising.
Power Plier
The next generation of SOG multi-tools, the 4 Power Plier is comparable to the Super Tool (above). It's the only one that uses compound leverage to multiply the force you apply, so you can generate twice the gripping or cutting force of other tools. This is a good thing, because the Power Plier is also the least comfortable of the tools: If you squeeze even lightly on the handles, the metal edges feel like they'll rip you open. On the bright side, the gears do allow for easy opening, and they give the tool a very smooth action.
SwissGrip
Having watched multi-tools take a chunk out of its Swiss Army Knife market, Wenger has struck back. The 5 SwissGrip is a serious chunk of metal, with super-tough pliers. In addition to the usual selection of drivers and widgets, there's a four-inch blade -- much bigger than any of the others -- and a wicked wood saw. There's also a nifty socket adapter built right into the side of the tool. As you'd expect from Wenger, everything is well-made and fits together in a balanced package. The only drawback is the overall size of the tool.
Multimaster
For the sportsman who likes the unadorned and uncomplicated, there's the 6 Multimaster from the Utica Cutlery Company. There's no flipping, twisting or untangling parts here -- just well-machined, heavy-duty simplicity. All the tools lock via a foolproof channel "L" locking device that is part of the Multimaster's design, not an afterthought. it comes with two universal Phillips/slotted bits that fit snugly into a 1/4-inch recessed bit cavity in the end of the handle. the Multimaster has the fewest moving parts and therefore the fewest possible points of breakdown of any of these tools.
Sport Mechanic
Coast produces eight different products on the low end of the multi-tool price range, the best of which is the 7 Sport Mechanic. Although the quality of construction is clearly below that of its higher-priced competitors (getting the scissors out is particularly frustrating), this is not a bad tool for the frugal sportsman. The spring-loaded pliers make it the easiest of all these tools to work with one hand. Unfortunately, the blades don't lock, and there's no small screwdriver. I wouldn't count on the Sport Mechanic out in the bush, but it's enough for knocking about the house and yard.
Pocket Wrench
This one is so different I couldn't resist including it: Instead of pliers, the 8 Coast Pocket Wrench has an adjustable wrench, along with the usual knife-and-screwdriver setup. Now, calling this is a tool is being generous -- the cheesy chrome flakes off on your hands and it's so poorly put together you could use it as a baby rattle. But what do you want for $10 bucks?
Multi-Lock
Gerber's newest multi-tool is the 9 Multi-Lock, featuring a "dual locking SAF.T.PLUS system." Which means that a spring-loaded bar locks each blade into place until you unlock it with a plastic slide mechanism. The unique one-handle opening feature -- a flip of the wrist exposes the plier jaws, which slide back into the handle when you're done -- makes this one of the more convenient tools out there. The real elegance of this tool is that all the components move smoothly and independently of the others, so when you want the knife, you get just the knife, not all the tools next to it. With all that moving and sliding, the Multi-Lock doesn't feel as solid as some of the others, and it twists a little when you bear down on the handles. It's probably not the best for heavy-duty work, but it'll handle most sportsmen's needs.
Schrade Tough Tool
The undisputed champion, in almost all the aspects of multi-tool performance, is the new 10 Tough Tool. The Imperial Schrade Corporation obviously took a long, hard look at all the other tools out there to see how they could be improved upon, and the results are impressive. There are two obvious innovations: You can access all the components whether the tool is open or closed, and the contoured handles are incredibly comfortable, allowing a wider grip for more power. you can squeeze for all you're worth without hurting yourself. Flipping the tool open with one hand is no problem, and all the important tools lock. For comfort, convenience and power, the Tough Tool is tough to beat.
Citation:
Source Citation: Monahan, Philip. "Tool time: sporting gear - multi-tools." Outdoor Life 200.n2 (Sept 1997): 90(2). InfoTrac OneFile. Thomson Gale. 6 DEC 06.
I couldn't find any other comparable article, and it looks like they had a soft sport for the Schrade.
hmmm. that must not be the latest one maybe? The other guy said the LM came out on top.
thanks for the stellar investigation tho!
Way not the latest, and not terribly objective, either. Consumer interest magazines are seldom a good source for impartial reviews, since they have to make nice to advertisers.
Sheesh! That article was written in 1997? I can remember reading it back then with considerable interest.
(Ohmygoodness, I didn't realize..........I've been a multi tool geek for going on ten years!) :o
The article was actually from Field and Stream, the June 2006 Issue. Members tested the Leatherman Surge, Gerber Freehand, SOG PowerLock and Wenger Evolution S 557.
If you were looking for the Surge (introduced 2005) it was the F&S article, but the Supertool came out awhile ago, so that would be one from an earlier date.
Thanks for letting me know where to look.
Section: FieldTest
READER TEST
GEAR REVIEWS YOU CAN TRUST Multitools that fit your hunting and fishing needs
THIS MONTH OUR TEST PANEL cut cardboard, whittled wood, twisted and cut wire, and loosened rusty bolts, all in the pursuit of raring the best new multitools on the market.
The tools were graded on blade and tool design, functionality, and stamina. All models were introduced within the past year, and in the case of the Gerber Freehand, our testers were the first consumers in the country to try it out.
FIELD & STREAM'S only requirements: Each tool had to have a knife and a pair of pliers and be applicable to hunting and fishing, Turn the page to see how four multitools rated.
# JUNK
## LEAVE IT IN THE TOOLBOX
### WORKMANLIKE
#### SOLID FEATURES
##### STATE OF THE ART
BEST OF THE TEST 1 Leatherman Surge ($80) OVERALL SCORE ####@
THE LOWDOWN This classic multitool has a selection of four screwdrivers and four measuring surfaces in inches or centimeters. There are nine lockable blades and tools with a file that stores in the nylon sheath and replaces the saw as needed. The outside blades are notched for thumb opening. Weighing 13.4 ounces, the stainless-steel Surge has a matte-and-chrome finish and comes with a 25-year warranty.
The panel gave the Surge a minor knock for its somewhat sharp outer frame and a perceived lack of durability for the file and saw blade holder. Besides that, it drew solid scores across the board, and it didn't receive a rating lower than second from anyone.
HITS "It's the only one with a screwdriver bit small enough to tighten eyeglasses." — Nicovich
"The knives can't be opened when the pliers are deployed, an excellent safety feature." — Koptiuch
MISSES "The file-to-saw blade exchanger seemed weak." — Kleto
CONTACT 503-253-7826; www.leathcrman.com
2 Gerber Freehand ($90) OVERALL SCORE ####
THE LOWDOWN One hand is enough to operate this tool, which has sliding needle-nose pliers and extremely tough wire cutters. At 14 ounces, the Freehand is the heaviest of the four tested. It comes in a nylon sheath and features eight lockable blades and tools, including one of the sharpest serrated blades. The stainless-steel finish is rustproof.
The testers raved about the Gerber's convenience, and all but Michaels liked how quickly the pliers deployed. Koptiuch severed a heavy 8-gauge fence wire with them, though he needed two hands to do it and got a nasty blood blister in the process. Not everyone thought the sliding pliers would hold up, but nobody could get them to fail. Michaels wanted to see the lock button increased in size for easier use.
HITS "The only multirool that opens with a flick of the wrist." — Nicovich
"The thumb knurls that you use to open the blades are a standout feature." — Koptiuch
MISSES "Sometimes the palm of my hand got pinched when I released the sliding pliers lock." — Koptiuch
CONTACT 800-950-6161; gerbergear.com
3 SOG PowerLock S60 ($75) OVERALL SCORE ###@
THE LOWDOWN Made in the United States and the only tool in our test with a ¼-inch socket, the SOG is best known for the leverage of its pliers. The S60 weighs 12 ounces, comes in a leather sheath, and has nine other blades and tools. With a smooth finish, it contains wire cutters, a wire stripper, and well-machined needle-nose pliers. The Power-Lock has a lifetime warranty.
Everyone liked its high-quality construction, sharp blades, and comfortable in-hand feel. The ¼-inch socket driver was a big hit, although some feared the nut could be easily misplaced. Three testers objected to the fact that the pliers had to be opened in order to use the other tools.
HITS "SOG's geared hinge creates compound leverage that is buttery-smooth and provides effortless gripping power." — Koptiuch
MISSES "The gap in the wire cutters prevented me from cutting fishing line smaller than 10-pound-test." — Nicovich
CONTACT 888-764-2378; sogknives.com
4 Wenger Evolution S 557 ($60) OVERALL SCORE ##@
THE LOWDOWN This multitool's primary features are its compact size and weight. At only 4½ ounces, it was by far the lightest tool in the test. It has one locking blade and seven other tools including pliers, scissors, two screwdrivers, a corkscrew, and more. Fear not, you still get the toothpick and tweezers.
Every tester credited Wenger (Swiss Array) as being the father of the first multitool, but that wasn't enough to keep the Evolution from scoring in the cellar. It just couldn't overcome its small and less-than-aggressive tool profile. There was general agreement that the S 557 would work fine for backpacking and camping. One tester commented that it was like comparing a BMW sedan to a ¼-ton diesel truck.
HITS "I liked the small wrench tool." — Kleto
MISSES "The pliers are only as strong as your fingers." — Nicovich
CONTACT 800-267-3577; wengerna.com
"Just hold the Surge and you know it will stand up to a lifetime of punishment." — STEVEN NICOVICH
"I can slide out the pliers and release a fish with one hand." — NICK KLETO
"I would only buy the SOG if it were on sale." — NICK KLETO
"If a person were restricted by size, this would be the tool." — STEVEN NICOVICH
THE TEST PANEL
Kent Koptiuch
HOME WOODS:
The Green Mountains, Vermont
ANNUAL DAYS IN THE OUTDOORS: 40
Nick Kleto
HOME WOODS:
Outer Banks, North Carolina
ANNUAL DAYS IN THE OUTDOORS: 90
Steven Nicovich
HOME WOODS:
Southern Oregon
ANNUAL DAYS IN THE OUTDOORS: 100
Curt Michaels
HOME WOODS:
Au Sable State Forest, Michigan
ANNUAL DAYS IN THE OUTDOORS: 45
BECOME A GEAR TESTER! GO TO FIELDANDSTREAM.COM/TESTPANEL
BEST OF THE TEST
OVERALL SCORE ####@
OVERALL SCORE ####
OVERALL SCORE ###@
OVERALL SCORE ##@
And here's Multitoolguide's
Multi Tool Comparison Chart
-http://www.multitoolguide.com/tools/
And MultitoolORG's
Comparative Multitool Weights
-http://multitool.org/content/view/34/71/
