maintaining the edge
What do you use to maintain your edge on your axe while in the field, to keep it shaving sharp? Also can you get an axe shaving sharp with a norton axe puck?
Thx
The axe puck really works well in the field and it's easy to carry. We use the Gerber and it runs about $7.00 The Lansky Tool Sharpener, which is an oblong stone, is only $6.50 and the Lansky Puck which is a dual grit carbide is $7.50 so it's not expensive to keep a working edge on your tools.
A file for any accidents which visibly damage the edge and a fine/x-fine dmt folding hone to set the edge and sharpen it.
Yes but you want a finer edge finish for optimal performance.
-Cliff
I saw a some kind of a diamond honing rod used before, it had a red handle and the rod could be unscrewed for easy packing. Thought it was made by a company called fiskers but I've had trouble finding it.
That sounds maybe like the Lansky or the Eze-Lap. The Eze-Lap Diamond Sharpener folds up for easy packing. Gerber makes a nice on that folds into a small leather case.
Smith's pocket diamond sharpener works well too, it has two grits, 325 and 750, and the handle is also the case. very handy tool.
