My current EDC is a Benchmade 556 mini-grip, partially serrated, in 440C. 556S-BLU. I love the ergonomics, size, and the way the steel takes an edge. What I don't love are the serrations.
What I would really like to do would be to regrind the primary bevel in the serrated portion of the blade to give the edge a recurve profile, eliminating the serrations and giving it a huge cutting advantage with a recurve at the same time.
Would this be a reasonable idea?
Possible problems as I see them:
1)The steel may be hardened only at the blade edge, and then left softer and more durable near the spine, and grinding off that much material may remove the harder steel if this is the case.
2)Removing a good portion of the material near the hilt may make the blade significantly more succeptible to breakage.
And if neither of those poses a problem, then what is the best way to go about actually re-profiling the blade? Would I be well served to use a slack-belt sander, or a grinder, or a mill with a carbide tip to mill out the new profile, or hours of tedious hand grinding with stones. Or just abandon the idea, and use the knife the way it is.
Any and all advice or comments would be great.
Thanks
-Jake
Thanks
-Jake
