- Oct 27, 2018
Do you have any clue what the material is?looks like it was machined or done with cnc.
That pattern is called "Anso" pattern.I was wondering if anyone could tell me the handle material and how to get that texture on a knife handle. I really like it and I want to use it on my next knife.![]()
It s look very easy on that video but I advice you to practice on some cheap material ... lot of practice before you try on real handleThank you. That’s what I though. As I’m a beginner what respirator should I get and wear should I get a thick enough amount of G10? Once again thank you.
Yes of course. Just regular wood that’s cheap? Like a pine?It s look very easy on that video but I advice you to practice on some cheap material ... lot of practice before you try on real handle![]()
It well be much easier if you start like this for example .Measure which Dia. you want and mark handle in equal distance like on this drawing .Then sand all of them just a little to mark position.That way if you make mistake you can still make correction.After that start to raise sanding .... Post picture when you try ... good luckOk thank you very much.
...what respirator should I get and wear...
