Making a KME guide handle from Ace hardware screwdriver -- Plus homemade KME base
Hi BF folks,
I recently acquired a KME and one of the first things I heard is, 'you'll want a handle on the guide rod' and 'you'll want a base'. So, this morning I was wondering around my local ace hardware and realized one of their small screwdrivers is the perfect size and also has a hole already in it. So, I took a 1/4 x 20 tap and made some threads in the screwdriver handle. It's super easy, maybe took 5 minutes.
I think it turned out great and for $3 bucks, I now have a handle for my KME. Hopefully this can help someone else if they want to make a handle vs. buy.
Thanks for the tip, will do. Hopefully not to much of a change, the screwdriver end itself is fairly light plastic with the metal insert. But will definitely keep a watch out on my next sharpening.
Hi BF folks,
Love your thinking and practicality. :thumbsup: :thumbsup: :thumbsup: Did the screw driver have different size transferable blades and therefore the hole you had to thread was already there? I really like when someone comes up with ways to mod things to their needs or just making them better generally. Well thought out and done.👌:)
Thank you! :) Yeah, I typically try to make things myself from stuff I have laying around or just thinking a bit outside the box. Here is the bit that was in the handle before I threaded it.
Here is the base I made today for it as well. I ended up using a piece of Europly I had laying around in conjunction with a 1/4" x 5" piece of pipe with washer/nut. I started by cutting the Europly down to a 6x6ish size, routed the edges, drilled a hole in the center, countersunk the bottom for the bolt, and then epoxied it in place. For the piece of pipe, I cut the threads off one end and sanded down to a tapered 1/2" diameter for the KME handle. I kept it removable so I could break it down as well. It took a bit of time because I used basic hand/power tools. Fun little project and now I have an upgraded KME 😄
Good to see you are thinking outside the box and doing your own thing, another advantage of doing what you are doing is that you can customize to your needs. I recently completed this sharpener to suit what i was looking for, made from parts i had lying around with some things i had to purchase, but it is made for what i wanted.
Wow, that's next level man, nice work!
Thanks, it was just something i always wanted to have a go at doing. Back to your project, from what i have seen about the KME and talked to people about, one fault could be that the handle did not sit on the stand securely and there was a fair bit of wobble when you held the sharpener, looks like you have eliminated that. :thumbsup: 👌
