jamesraykenney said:Do I need a polished blade before etching with Radio Shack etching solution?
olpappy said:Actually you want a surface which is not fully polished, as a full polish tends to not etch evenly. What you want is a fine grit hand rubbed surface, for example 600 grit or 1200 grit. So if you're starting with a villager you'll need to user finer grits, if you're starting with a polished kuk you'll have to dull the surface first.
There have been numerous threads on etching in the past, just do a search in the forum using the keywords you're looking for.
