daizee
- Dec 30, 2009
Hi Makers,
I'm cautiously embarking on a new "knife-making" project that is quite a bit more ambitious than my last attempt (chronicled here in this forum) a year ago, and need some helpful advice from those with experience. My first, and thus far only, knife-making project a year ago taught me a LOT about what it takes to make a knife. Chiefly how difficult it is! It became quite clear that I don't have the tools or skills to do the job by hand.
I have a knife design which I would like to prototype by contracting out much or all of the work to a CNC shop.
I have a bunch of CAD models which are little more than drawings IN a CAD program. I'll need to clean those up into something a shop can use.
The current plan is:
1) have a fab shop with a waterjet machine cut out the carbon steel blanks. If possible, I'd like the same shop to put the primary grind on the blanks to reduce the number of steps.
1.5) possibly have the same shop cut out the scales as well (wood or micarta)
2) Send the blanks to another shop for heat-treat
3) Edge them at home?
4) Finish the handle scales and install
5) Send out a sample or two to have kydex sheaths made.
I plan to hex-bolt the handles on with probably 3/16" shank bolts with a 1/4" or so counter sink. I haven't selected hardware yet and thus haven't confirmed the sizes for sure. This will let me swap materials and colors until I'm happy.
Scales could also be cut at home if necessary.
I'm going to try to keep all the work local as the economy here sucks and I'd like to help. I expect to have a small budget for the project in the new year.
Does anyone have an gotchas I should watch out for?
Is a fab shop likely to be able to do the primary grind as well as the blank?
I've had a couple very early conversations which got me focused on creating a CAD model, but not much more than that. I plan to have a batch made to keep the cost per knife reasonable, and hopefully sell off the extras, give them as gifts, trade, or whatever seems appropriate.
Thanks for your input,
-Daizee
-Daizee
