Making a thumbstud
Now that I'm the proud owner of a lathe :D, I wanted to make a thumbstud for my first liner lock.
But I ran into the problem that after I drilled my 1,6 mm hole into the 4 mm round stock of brass and threaded the hole, I can't work the actual stud.
The problem is if I cut of the threaded "raw" stud how can I chuck it into the lathe to work on it on the full lenght? Do I need a special fixture or is it impossible to work on such a little (ca. 8 mm long) piece of round stock in the lathe?
If it's not clear what I'm asking, I'll put up some pictures.
Thanks a lot for your help.
Regards Marcus
Take a piece of larger round stock, clearance drill a hole through the center, then screw the little stud to it, then chuck the assembly up?
That's not how I'd do it, but I don't have a lathe, so I would do it in a mill...
Say hello to the machinsts that will show up and correct me...
