I think the diamond plate plays a big part in this. There is a HUGE difference between an Atoma 140 and the Nano-Hone NL-5 that I used. The Atoma 140 is for lapping coarse stones. The NL-5 works on stones up to 30K. I have a full set (140/600/1200) of Atoma's, and the finish the NL-5 leaves is night and day different.
Again though, to each his own. I did that to make the surface of the Ultra Fine bench stone as uniform as possible, as when these are new, the surface is surprisingly non-uniform. You can still see the swirl (Saw?) marks from whatever they cut or grind those things flat with. However, after the lapping process I described, the surface is DEAD-FLAT, but is still cuts.
The biggest thing I like about the NL-5 is the surface finish it leaves. It is uniform and smooth, but not glazed and/or shiny. You feel the raw texture of the stone, but there is no glazing when using that plate. I'm not trying to sound like an advertisement for Nano-Hone, or the NL-5, but the finish these things leave is just incredible, and is nothing like even what a 1200 grit Atoma leaves.
Now I have to admit I don't use it for a finishing stone when I sharpen like I would a 2K or 4K Shapton Glass water stone. I use the Ultra Fine Spyderco as a hone to keep my knives sharp between actual stone sharpenings, and will bounce back and forth between the UF and a strop loaded with diamond compound to maintain sharpness.
