- Sep 14, 2010
Are there any suppliers that sell parts (particularly springs) to make AO knives? Also any tutorials on making these?
Knifekits.com sells a button lock kit and springs Look under under folders for DDR-3BL and parts for same. Could that system be used?
When I first started looking into knife making, an AO knife is what I really wanted to make. I picked up a couple cheap
($5) ones at a knife show just to take apart. One of them has a long flat spring that was cut out of flat stock. I have read threads that suggest using that type of spring and not the wire type. What I'd like to do one day is to just trace the parts and cut them out and see if they will work when I put them together. Maybe do that several times, making changes along the way.
Not what you were looking for, but maybe it'll help.
Maybe something from this site
http://www.assistedknife.com/index.cfm/fa/categories.main/parentcat/26098
also if u decide to make your own wireform spring i recommend using square wire as its stronger, perhaps .04" wire diameter would give it a healthy snap, if youd like i can email you a cad drawing of a wireform i copied from a flea market knife. its diameter is .01 which was weak so experiment with different size wire. best of luck matt
