Ok, this is coming word for word from an add in Cabela's for a Boker Gama ceramic blade knife.
" Boker fashions the 2" drop point blade from their black zircon oxide ceramic, which is as hard as diamonds ( so hard it registers beyond the rockwell scale)."
" Its the same material used for tiles on the nose cone of the space shuttles."
The part that says its as hard as diamonds is wrong. They say in add for another boker ceramic knife that the only thing harder than black zircon ceramic is diamonds. But that means that to effectivly grind it, you have to have a diamond abrasive. And that doesn't mean those DMT stones with a nickel bonding agent. And your not going to drill a hole in it with a carbide drill bit either.Seeing as how diamond is harder than carbide,those spade bits may break it, but not drill a clean hole. And it would probably eat them up pretty quick too.
When I called it a composite, I meant it was composed of a couple different minerals or elements that are ground up into a powder, then bonded together under extreme heat and pressure. Thats where the 4 days in a 3000 degree furnace come into play.
Bottom line is it takes so much equipment to make a ceramic blade knife, that its only profitable to do it in mass quantities, the same way that boker makes pocket knives, and other companies are making kitchen knives out of ceramic. And chances are you won't be able to get access to the equipment or materials you'll need to do it
A ceramic straight razor is a cool idea though
Fix it right the first time, use Baling Wire !
