Well , i'm working on another belt grinder so I need idler wheels . I Intend to make them from front forks fork tubes from Honda Transalp bike .They have hard chrome surface and 41mm outer dia. 6301 ball bearing will fit perfectly with little work on lathe .41mm outer diameter make them perfect for press fit of rubber , silicone or polyurethane tube with 40mm inner Dia . with 5mm wall thickness .
Now , somewhere on net I found this ......
Is there any advantage to use bearing this way ? What do you think guys ?
