Seen a few references people made to home-made micarta. My searches come up with way too much info of nothing at all. Could someone please what is ment by home-made micarta? How is it done?
Thanks..Curt
Something I thought about trying is to take two colors of heavy paper - black and gray for instance. Cut them in strips about 1-1/2" wide and saturate them in 24hour epoxy. lay some waxed paper on a very flat, level surface and start laying the saturated paper strips on top of each other. laying them down like you would gluing sheet material with contact glue working the bubbles out. Finally, lay a layer of waxed paper over the stack then a block of wood topped of by a bunch of weight. The whole assembly could be clamped if this process started out with a peice of wood.
Also thought about stacking a bunch of strips of fiberglass screen in a form, pouring epoxy in the mould and compress - may be interesting or may totaly suck.
Thanks..Curt
