- Feb 19, 2010
Hello there
I am going to make my first knife handle as a summer project with a friend of mine.
I will be using this blade: http://www.thegoodstuffshop.dk/product.asp?product=13513
I am thinking that I'll be making it from a piece of some kind of wood on the top and bottom and a larger piece of buffallo horn in the middle.
Now I am wondering how you mount the knife into the handle, I want the tang to be hidden (except for the screw in the buttom) I am thinking that you stack the handle pieces ontop of each other in a approximate shape and then drill all the way through it, but the tang is flat and i dont know if it will be stable for batoning and such if you push it through a round hole where there is air in the sides?
Then what i was thinking is that when it is flush at the end of the handle you drill inwards with a larger drill a bit so the end screw can fit on and be lowered into the handle so that it is flush, if that makes any sense?
I am hoping you will give some suggestions on a good way to do it, I'll greatly prefere not cutting the wood blocks in half and mounting them on each side.
also, will a knife of this kind hold up to batoning?
Thanks
Thanks
