Photos Making my first knife!
After over a year of watching “how to” videos and reading forums, I finally found the courage to try to make a knife via “material removal” method. Dad has always said i should try my hand in m knife making.
The knife started life as a flat piece of 1084 carbon steel, 12” long, 1 1/2” wide and .125” (1/8”) thick.
I drew several templates until finally settling on one. After that, it was rough cut to shape via 4” side grinder, hacksaw, a 1” belt sander and files.
The primary bevels were filed by hand, which took approximately 3 hours per side via use of my homemade bevel jig.
Holes were cut into the tang (handle) for the alignment pins, as well as a couple others holes used to give the epoxy a better bond.
The entire blade received an initial sanding at this point.
To make the metal a usable blade, it had to be l hardened via the use of wood burning fire in our chiminea. I had to employ a hair dryer (gives the fire more oxygen) to get the fire hot enough. I heated the knife to non-magnetic, which is approximately 1300 degrees, then went another couple hundred higher, which was a bright red color. Once it reach that point I quenched the blade in vegetable oil that was heated to approximately 140 degrees.
The above process made the knife very hard but also brittle, so I tempered it in our home oven for two hours at 400 degrees for two cycles, allowing the knife to air cool to room temperature between.
Once that was done the entire knife had to be resanded to remove the carbonization and scale - byproducts from the whole heat treating process.
After that, I began working on the handle scales, which I used stabilized mesquite wood from Ezzell, TX. The scales were shaped via files and the 1” belt sander and affixed to the tang via two 1/4” brass pins and a two part epoxy. After curing for 24 hours, the pins were cut down close to the scales and everything was sanded and contoured, paying attention to the overall fit and finish. The last step was applying tung oil to the scales.
I really enjoyed this project, honing my skills further in metal and wood working, while breaking the ice on a new craft. If you’ve made it to the end of this post, Thank You!
Well…after all this typing, I can’t figure out how to post photos…
Great looking first knife Cody, you avoided a lot of “new maker” traps! Stuck with mostly hand tools, nicely radiused handle, and decently thin behind the edge. If that’s the first I can only imagine what the 100th will look like!
Congrats on your first finished blade and cheers to what is hopefully a long and fulfilling journey through knife making. Happy new year!
AWESOME JOB.......... I don't think my tenth knife would look that good or my 30th.😜.......I don't make any!!
I know better.. I buy em..😉.....
Keep up the good work and please DO SHARE your next project.....👍👍👍
James
I appreciate the compliments yall! I already have two more rough cut and plan on starting the bevels today. These will be more of a compact design, good for EDC.
I was kind of worried because pre-heat treat I was .050 at the edge, prior to grinding the secondary bevel. I’ve heard you keep ‘em fat pretty-heat treat to reduce the edge being wavy etc but .050 seemed a bit much.
However, the turned out pretty decent and usable.
Nice Job! Looks miles better than my first knife and many after that-
Looks like you have a great start!
Linus
As others have said that’s a great looking first knife. Good job picking blade material and coming up with a simple profile.
Now use it for its intended purpose and see what you like and dislike about it before you make more. Focus on dialing in the fit and finish. Hand sanding is an art in and of itself.
I look forward to seeing more of your work.
Sorry to be late to this thread.
Welcome Cody. Fill out your profile so we know where you live and a bit about you.
As said by the others - Nice looking first knife.
Some suggestions for future improvements:
1) Try curving the clip down instead of a sudden angle.
2) Work on the handle to make it less fat and have a little roundness. Most every first knife suffers from BHS (blocky handle syndrome). BHS is where the cross section of the handle is still pretty close to a rectangle instead of oval or egg shaped.
That’s a great suggestion on using to really dial in its pro’s and con’s. I can really agree that the sanding was probably one of the most challenging aspects, as I didn’t quite get it to where I wanted it.
Thank you for the suggestions and compliments.
Cody
Thank you and will do. After completing it, the handle feels a bit “large” in the hand.
Cody
I just filled out and attempted to save my profile but received an error message on the lines of, “couldn’t be submitted because the website detects spam”.
I tried to private message ton but couldn’t figure it out.
It can be tricky sometimes.
Click on you name in the blue header bar
Click Account Details in the drop box
Change/add the info
Click SAVE
