I am looking to make some wood scales for a couple folders. All of the wood/micarta I have is too thick - looking to get if from about 1/4 inch to about 1/8 inch.
Any suggestions on how to do this, with minimal tools?
Hand sanding is my fall back - but looking for something a bit faster? This may be a good excuse to buy more equipment.
I tried a friend's HF 4in sander - the thin pieces of wood would slide under the guard and get sucked in. Too much clearance between the guard and the belt.
-- I was considering - random orbital sander? Never tried this on a small piece of wood - not sure if it will stay put? Perhaps if I put it on a silicone/sticky pad?
-- gluing the scales to a larger piece of wood, then orbital sanding that? I worry that even with CA debonder, the 1/8 inch scales may crack a bit?
-- good old elbow grease?
On a separate note - to avoid this problem in the future, would buying thicker stock, then using a scroll saw help? I can't imagine the scroll saw cuts too straight (meaning - I wouldn't cut too straight...).
Or is the secret to buy it closer to the proper thickness to begin with?
Thanks for your thoughts.
