Making wood strops — how do you prep them?
OhioApexing
Sharpener
I’m getting ready to put together a few wood strops for diamond compounds — some basswood, balsa, and a couple of other non-traditional woods that I think could work well for stropping depending on application.
Anyhow, do you sand yours prior to loading them? If so, to what grit?
the basewood ... I just had mine planed to level and let them break in through use ... they were fairly smooth and didn't need sanding after having them planed flat.
The balsa wood I bought was already flat and didn't need any sanding or flattening.
Yeah, the wood I have is planed and good to go there, I was thinking about surface texture and absorbing the sprays/emulsions.
I don't know how most prep a wood strop ... I'm fairly new to using them but I had good results just applyimg diamond pastes and using them ... I started with some less expensive knives ...
I assume the diamond pastes polished the wood as I used them ... they are smooth like they were fine sanded now and give good results.
Not much prep needed, if any at all. If the wood is uniformly flat and smooth, with no bumps or undulations, it's likely ready to go. If it's dirty with some embedded grit or grime, then some sanding can clean that up. A relatively coarse grit made for wood-sanding, like garnet paper at 100 - 150 or so, works well and is coarse enough it'll be easy to see (& feel) if any of it's grit is left behind. And the garnet is somewhat less likely to leave deep scratches on your blade (like SiC/AlOx paper can), if for some reason it's left behind on the strop. That doesn't happen much anyway, as the grit is easy to brush or vacuum away from the surface, after sanding.
Planing the wood is very handy when it comes time to replenish them after some heavy use, or if you want to try a different compound on them. Planing will completely remove the top layer to some depth, so there's little risk for contamination by a coarser grit left behind. Also works well to remove any wood filled with whatever emulsion might've been used (oil, etc.), leaving it completely clean and as-new, and impressively smooth & flat as well.
