I really like the idea of carrying a smallish saw, rather than a huge knife or ax. I had seen it suggested that a useful alternative to the usual folding Opinel or similar folding saw was simply a jab saw. Looking at jab saws I came across a few folding saws, including a Milwaukee brand product that allow you to both fold and change the blades.
Milwaukee uses they Sawzall blades in this folder. That got me searching around some more, until I found this:
The small saw is commercially made, but the larger gray one is handmade of a Sawzall blade, folded kydex and a rivet. That's all.
Reciprocating saw blades come in multiple lengths up to 12", and in everything from 5 TPI on up starting around $3. Kydex is one solution, if you have the thick stuff or make it in two layers. The other way to go is with a lightweight wood with a blade-width slot and use a cross screw or rivet for a pivot (the blades come with a hole in them) and another cross pin as a blade stop. You can even buy a longish blade and cut it down to whatever custom length fits your belt or pack.
And as we've seen from the Mora Classics and Opinels, a nicely hand-filling wood handle makes for a lighter tool than plastic does. Basswood or even pine may work, but beech is proven in the Opinels and Moras. And you can use the purchased blade to cut the channel to the perfect width.
Anyone see a problem with this?
