Making your own kydex sheath?
I've been looking at the kydex making tools on knifekits and similar sites. Thinking of getting into this as a little hobby. Anyone played with this before? Any tips or other sites I should look at?
Also thinking I could use the same size press for most handgun holsters, but would I need dummy guns or could I use the actual pistol?
Hey Guys...
This will probably should be moved to the Q&A section....
First off,, stay away from the Northcoast Knives Tut..No offence,, but a Very amateurish, primitive way of making a kydex sheath... Too complicated, and too much work for the end result, which is,, Another poor sheath.
The use of the Heat Gun is correct though...:)
Hot plastic won't hurt your firearms..
It's not that hot, and doesn't stay hot for long enough to do any damage...
Knifekits "Waffle Iron" presses are Ok,, but not what I would use...
They'll get the job done, however with scrap kicking around the garage,,you can make one.C-clamps and quicky clamps will work much better...
ttyle
Eric....
