- Sep 23, 1999
I got a batch of drop points back from heat treat and took 4 out to start working on them. After using a 500 grit to knock the rough off em, I used a 600 grit and then I took an old grinder rock and ran it across the 600 belt till it was major worn out. Then I made sure it was clean and sanded the grinds. It got them shiney, but not real shiney. Then I went to my 6 by 48 and did the same thing with a 600 grit belt and sanded the flats. Man did those flats shine up and real fast too. This made me decide to go back and work the grinds again to see if I could get them that shiney. I was just about to put the belt back on my Wilton when I thought, the 6 by runs way slower than the Wilton. So I put the belt on my home made variable speed sander and set it on the slowest speed. Same results. Those hollow grinds came out at least 80% as shiney as I usually get them on my buffer. I guess the slower speed really does make a big difference. This is gonna cut my buffing time to just a couple minutes per blade and that should keep the grind lines sharp as well. Wish I had found this out along time ago! Man do I hate buffing!!! Take care!! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
