Manix 2 Blade Play
1st1903
BANNED
Hi all
I have a Manix 2 in M4 that ive had for a couple of weeks now, and it has a fair amount of blade play in the handle when it is folded and a little side to side play when it is open. I have heard that the closed play is fairly common in Manix 2s. I was wondering if there was any way I could fix it? Thanks!
Sounds like you need to tighten some handle screws: pivot pin, stop pin, etc.. Both my Manix 2's exhibit no bladeplay whatsoever.
All are as tight as can be without inhibiting easy opening
If the pivot screw can be tightened to a point where it starts to get harder to open, then it's all about making tiny adjustments until you find a sweet spot. A tiny fraction of a turn can change tightness quite a bit. Using some blue loctite during adjustment will ensure it won't loosen up.
I got my M4 Manix 2 to where it still has free movement but no play.
The Manix2 should have a pivot with a bushing around it (similar to the Sebenza), so technically tightening the screws beyond a certain point should not be possible. I hope I am not mistaken.
As for the bladeplay - deal with it. It's a pocketknife, not a vault :p
I have handled *very* few pocketknifes without any play, it's basically just a matter of how picky you are. It's not big issue in a folding knife, especially bladeplay when closed wouldn't concern me at all.
The pivot "bushing" is not actually a sleeve around a pivot bolt. Instead, the Manix 2 has a stepped pivot bolt with shoulders that allows for a zero-friction pivot action.
Yes, and going with a Sebenza-type arrangement would likely require a substantial uptick in production costs and therefore selling prices.
I have to ask JNewell, what is that in your 'avatar'? I don't know if I should be disgusted or turned on or what. Just curious :)
