I did some testing today with some thick branches. Batoning, cutting bark off, splitting the branches etc.
I will say I beat the crap out of the knife with an loose axe handle with most of my strength. I simply pretended it was a fixed blade.
During batoning, the knife performed well. The edge held up fine with no edge damage just a littel dulling (still paper push cutting sharp).However at the end of test blade play and a slipping lock were present (Same slipping that occurred in Ankerson's spine whack test). This means a slight push could disengage the knife and there was blade play up down and side to side. Measured by a scale it took approximately 10 lbs of force to disengage the lock, albeit not very scientific.
I took it inside, disassembled the knife, clean it, lubed it, and reassembled. During disassembly I noticed the steel back spacer had moved up a little, this caused the lock to engage further down on the blade tang near the corner of the locking surface, that is why it kept disengaging.
Knife is back to normal. Solid no blade play. A few hard spine whacks and the knife remained solid. The fact it is capable of taking that kind of punishment with no permanent damage is a success in my books.
Videos are incoming probably by tomorrow morning.
*I Do NOT encourage batoning with a folding knife*
