Manix 2 LW <—> Manix 2 G-10 Blade Swap (no destruction)
Preface: This will void your warranty and can be dangerous.
I was doing research on if this was possible, and was having trouble finding a solid answer one way or another, so I figured I’d make a post about it.
The tl;dr is that the swap works, albeit with some potential for clearance issues with how blades/lock bars were fitted from the factory as it pertains to the ball lock engagement (you may have to file down a bit of metal where the blade meets the lock bar). I don’t think that issue is specific to this swap though, I’d imagine it would be any Blade into another frame. Also, it is a pain in the ass, and takes time.
I picked up the Blade HQ M4 Manix 2 and really wanted that blade in a G-10 Manix 2 so I could customize it with a different ball cage, spring, and maybe down the road, scales. I also didn’t want to just waste the LW Manix.
The first thing I want to say is before you do this, dull the blade in your LW Manix and wrap it up. Don’t be dumb like me and end up with bandaid hands.
The first thing you want to do is to get items to help you wedge the scales apart. Guitar picks work well.
Place them between the copper bushings and the inner metal “frame”. The composition of the LW Manix (described like a sandwich):
1) bottom scale
2) bottom metal frame
—-> place guitar pick here
3) bottom copper bushing
4) blade
5) upper copper bushing
6) upper metal frame
7) upper scale
Once your picks are fully inserted you will be able to pop the blade out. This process of pick insertion took me about 45 min - 1 hour to complete, as I was trying to be careful not to break the scales or cut myself.
After popping the blade out of the LW version, simply install it in the G-10 version.
The process for installing the G-10 blade in the LW version can be accomplished by following the disassembly steps in reverse order. A couple of notes.
The pivot is keyed, don’t worry about this, it doesn’t really matter. It will just make you swear when you almost have it in and it spins. Just focus on getting the pivot mostly in place and once it’s there you can work the blade open and closed to “set it”
Another thing that you may or may not experience. With the G-10 blade installed in the LW version, my lockup was very poor. It seems there is some extra material on the G-10 blade. To fix this you can file down the lock bar where it meets the top of the blade.
All done!
Nice instructions. Do you think the lockup could be fixed with a different sized ball bearing, or is filing the backspacer the only way you think the lock up could be fixed?
Thanks.
Honestly not too sure, I think logically that makes sense considering you are just trying to get a few thousandths clearance for the ball to insert far enough. Worth a shot.
Another option would be filing down the blade, but I suppose that’s a pick your poison kind of thing. Depends on if you care about the blade or the rest of the knife more. To me the blade was worth more since I could swap it back into a different Manix if I wanted to I suppose.
Yeah I’d file the blade only as a last resort. The backspacer and ball bearings are easier to replace if you mess them up. I think I’d try the ball bearings first though as they are easy enough to come by either slightly undersize or slightly oversized. If you only needed to file the backspacer to get a few thousandths that is pretty easy work.
I've tried a different sized ball bearing after doing a Manix LW to G10 blade swap. Unfortunately after the swap to the G10 body, the lockup basically at 100% and there was no more room for wear. The standard sized ball is 3/16" or ~4.76mm. I got a 5mm ball as that was the next size up I could find and that brought the lockup back down, although it was almost too much. If there was a ball that was 0.1mm larger than standard that would've been perfect I think.
Is there a source for the G10 backspacer that you know of?
I’ve never seen a source for the G-10 backspacer that is needed if you want to put your knife in AWT scales like I plan to.
I went through a similar process Manix swapping. If only someone would start spitting out aftermarket G10 lockbars...
