- Mar 21, 2015
I just received my Manix 2 LW with S110V in the mail. The knife is pretty stiff to open. The buttons used to close it are REALLY STIFF to use. I also noticed that the blade sits a bit offset when the knife is closed. If I loosen up the two star screws for the pivot will this allow me to get the blade to be more centered and HOPEFULLY open and close better. Right now you can't flip the knife open with your thumb and get it to go more than half way between closed and open. It takes two flips with your thumb to get it fully opened. If you have both buttons pressed you can hold the knife vertical and hold the blade horizontal and let go it will swing downward and stop about halfway to being closed, that is how much internal pressure there is on the blade. You can actually tap on the blade at this point and it won't close all the way. You have to PUSH IT SHUT. This is really disturbing as every video I watched on YouTube prior to purchasing the knife opened without a hitch. Though some people said it was a bit stiff it still opened and even closed without trouble. I've got a wonderful knife that is just a bear to open and close but it works fine once opened! Any thoughts on what I can do?
Thanks in advance.
Thanks in advance.
