First be sure you use high quality bits I prefer Wiha ... and be sure they get seated all the way into the screw head.
If you have a soldering iron try using the tip held on the screw for a few seconds and see if you can get the screws loose then. Depending on the soldering iron it may take a bit longer but should loosen any loctite on the hardware.
