- Oct 8, 2013
Is the Manticore an oilstone or a waterstone.Thank You in advance.
It is either, according to your preference. If choosing to use it with oil you may wish to make use of the petroleum jelly filling method to reduce how much oil you have to use on the surface each session. But I use mine with water, personally.Is the Manticore an oilstone or a waterstone.Thank You in advance.
so just slather vaseline on the surface then add oil to saturation? or is the vaseline used as the oil?It is either, according to your preference. If choosing to use it with oil you may wish to make use of the petroleum jelly filling method to reduce how much oil you have to use on the surface each session. But I use mine with water, personally.
You warm up some petroleum jelly to the point where it liquifies and absorbs into the stone. A hair dryer is sufficient for this. Do this until it's pretty full. When it re-congeals you now have it occupying the core space of the stone, reducing how much oil you need to apply to the surface.so just slather vaseline on the surface then add oil to saturation? or is the vaseline used as the oil?
interesting
interesting
FWIW, coming from a newb like myself, you can also use the oven. I treated one of my other stones as noted byYou warm up some petroleum jelly to the point where it liquifies and absorbs into the stone. A hair dryer is sufficient for this. Do this until it's pretty full. When it re-congeals you now have it occupying the core space of the stone, reducing how much oil you need to apply to the surface.
Thank you, Gentlemen!FWIW, coming from a newb like myself, you can also use the oven. I treated one of my other stones as noted byFortyTwoBlades above, using petroleum jelly and a hair dryer. I apparently didn't use enough, though, so I had to re-treat it. I have a ratty, rusty cookie sheet that serves as a "project sheet" these days. I was going to set the oven for ~130*, but my oven won't turn on below ~175*. Accordingly, I put a layer of PJ on top of the stone, set it on the project sheet, and set the oven to preheating up to 175*. Before it reached that temp, all of the PJ had melted and soaked down into the stone.
