REgarding the 9" Delta saw, the real answer is no because the blade runs way to fast for steel, however, there's a few guys out there who say that you just run it until all the teeth melt off and then use it to friction cut the metal. IMHO, that's incorrect use of the tool and could present a danger if the blade fails. Wometimes on a wood cutting bandsaw when the blade breaks, it shoots out to one side and can be very dangerous.
Straight work with a hack saw can be pretty rough. The most common way is to drill a series of holes close together along the outside of your scribed pattern and then use the hacksaw to connect the dots. It makes the hacksaw route a lot easier as you remove most of the metal with a power drill. MAke sure to use a shapr drill bit and don't run it too fast or you'll burn the tip. Also, if you're using one of those cheapie stamped steel hacksaws with a hinge point in the middle of the frame to accomodate different length blades, put it in a dumpster and go buy a decent rigid hacksaw. Craftsman makes one where the main frame is tubing around 3/4" with cast aluminum ends. A good solid saw makes hacksawing much easier. Also make sure to invest a couple extra dollars into decent bi-metal blades with 14 or 18 TPI (teeth per inch). This will make your life much easier. Hope it helps.
John
