1.Am I correct that a MAP won't work with the GIB or EERF grinders? If so, how much does that matter for grinding liner/frame lock folders and small fixed blades with variious bevels?
2.Is the GIB the same as the EERF?
3.Are they the most compact grinders?
4.Are the NWG frame kit and Michael Clerc plans the ones similar to the KMG?
5.Will all work with a VFD?
6.Is VFD ideal?
7.Am I correct that for best use I need a 2hp TEFC, single phase, 220v, 1,800 rpm motor?
Or can I get plenty of power from a 110v 1 1/2 hp TEFC single phase, 1,800 rpm motor? I would have to wire in the 220.
8.I can put a kit together or have plan parts cut for me.
9.Anything I left out to help make my decision on which grinder to make?
THANKS!!!
6.Is VFD ideal?
THANKS!!!
