- Jan 9, 2008
I built a mini coffee can forge using two large coffee cans and some homemade refractory that I made using furnace cement and perlite. The problem I had was it did not seem to get hot enough except where the torches were hitting the steel. I used two small propane bottles.
Originally I left the back closed and thought that maybe it was not getting enough air because the rear burner did not seem to get going so I cut open the back and it did help but I still could not get it hot enough.
Now one thing that I found out was that the refractory had not entirely dried, I knew this because I could see steam coming from the unit and it would transfer heat to the outside of the cans.
I let it dry and tried it today and it still does not get hot enough. My questions to the experts are;
1, do I have to let the forge run for a while to get up to temps and if so what is a reasonable time to wait.
2, Can I swittch to mapp gas to make it hotter.
3, will I be able to use the same torch that I have for the propane with Mapp.
The reality is that I will probably only need the forge for heat treating right now because I want to learn the stock removal method before I start forging my own steel. The ole lady is not thrilled about having a forge in the basement. I can't say that I blame her so I will have to wait till spring to take it in the garage.
