I've been working on my first - I'm using Absolute Cheapskate Way to Start Making Knives as my guide.
I used the below method to mark how far to file the bevels:
thanks,
John-Boy
And it worked out okay in the end - especially for a first timer. But I was thinking there's got to be a better way. I had a hard time dragging a bit evenly accross the edge. Is there a better way for next time?"Mark the edge of the blade using a ¼ inch drill bit. Blacken the edge using a marker so your scribed lines will show up well. To mark the edge, slide the drill bit point along the edge and it will scribe a line. Turn the blade over and then scribe the other side. You will get two lines about .025 to .030 apart. If the lines are too close, re-blacken the edge with the marker and roll the drill bit to move the point up or down accordingly and then rescribe. The lines will be about one half of the thickness of a penny apart."
thanks,
John-Boy
