Martindale Paratrooper, first blush
Well, with my Golok seeming closer to the 44 than the 50 on the advertised 6 point Rc spread, figured I'd get another big knife to throw in the truck. Taking the paper off of the blade, buddy of mine said 'that's not a wire, that's a cable' Truly, there was not much finesse on the grinder for this one. Better than the Golok, as they did grind something akin to an edge at the 'tip', which is completely round due to profile and sharpened false edge. Both edges are ~25 degrees per side, and there is no other beveling anywhere on the steel, it's 4mm thick at the spine and behind the edge. Edge bevel is as wide as the stock is thick, and fairly even. Took the file to it just to break the wire, will sharpen later.
I like the heft, feels good for the 3" shorter blade. I can feel the weight about 7" from the blade/handle juncture when swinging, which is an inch further out than the tip of my RD6, so it should chop so much better once I get an edge on it. I'm really not keen on a 5-8" blade outside of the kitchen. Wondering what to do with the 4" false edge, I could make it much thinner for finer cutting, and choke up on the blade if I don't make the primary edge too sharp. But then I end up with a really sharp edge where I need to put my hand for a draw knife type hold, and I've left the primary edge unsuitable for that use anyway. Also don't want to shift around the balance too much by grinding a big relief.
Rust hasn't been a problem for the Golok, I just sand off any corrosion without care for the finish. But not having plain metal contacting the wooden handle is a good thing, and is a benefit to the black coating on the Para. There is a problem with the handle-loose rivet. One shot with a hammer and puch will fix that, though. Otherwise it's a useful shape and size, without any discomfort on hard impacts against some seasoned oak that laughs at all my efforts that don't involve 2 cycle oil. Will try to get some work on 2X4s once I drop the edge to about 20 per side. Though I doubt I'll beat those 5 second times from those competition cutters.
I'm tempted to use this, the Golok, and a Tramontina long handle cane knife together. But I've already literally ripped part of the edge on another cane knife, so I might skip it.
Anyone else interested in the Paratrooper, or any Martindale, should have a look around Cliff's site for an in depth review.
I'd actually like to know how they are sharpened, I would assume it is actually on bench grinders as you really can't burn an edge as bad as I have seen on them on a belt sander even if you don't cool it at all because there is just so much metal to absorb the heat.
I left mine out one year once it started to snow and picked it up the following spring. It wasn't significantly effected. It rusted, but wasn't destroyed. I gave it a light sanding and ripped a new edge on the belt sander.
Buy a piece of clear pine. How did you damage the cane knife?
-Cliff
It really seems like they use bench grinders. The edge is only slightly hollow in the middle of the edge bevel, so I'm guessing it's just pressed against a cutting wheel without much care for geometries of good hollow grinds. I'm going to go at both with an angle grinder to clean up the edge of the Golok and thin out the Para.
The cane knife met that oak a while back. Same friend who commented on the edge had gotten himself a very large tree that was in someone else's way. About 2 weeks after it was cut down, I helped him and his dad delimb it and cut rounds and some splits. I cut through branches up to 3" with the cane knife, until I went at one at a bad angle and tore the edge off. They swapped between a double bit axe and a chainsaw, but I had more fun :) This was about 3 years ago, now 2 inch branches on some leftover (ok, a lot of leftovers, this was a big tree) sound like I'm banging a tank when I hit them.
Yeah, well seasoned wood of most types gets pretty hard pretty fast, but if the wood isn't soft to begin with then chopping it is more for recreation than functionality.
-Cliff
I really just do it to check for vibration, no patience to actually go through stuff a foot in diameter.
