- Jun 22, 2020
So I got the knives.
Manly Patriot came razor sharp. Fit and finish are exceptional, except for grind not going all the way to the tip. And notch at the end of the blade is quite cornered as you can see. I tried to sand paper it quickly - no luck. I plan to round it with diamonds as this is potential hotspot that could cause the knife to break.
https://i.imgur.com/90m7929.jpg
Handle has good ergonomics, jimping isn't too agressive, blade is ground very thin, definitley a slicer.
They however forgot to make a drain hole on the sheath... but it'll be in my pocket, so it's not a big deal.
Now, Boker GoBag... came dirty and one of the handle scales is bit thicker than other.
And grind...
Before:
https://i.imgur.com/DkdrIo5.jpg
After:
https://i.imgur.com/wxvqTNZ.jpg
It feels good in the hand tho, sheath was at first too tight, but after a while and lots of shavings being made by thick bottom at the blade of the knife - now it sits perfectly.
About the steel:
It was amazing how the Manly Patriot resisted sand paper, even diamonds when I convexed the grind near the tip (I plan to convex it's entire edge in the future sharpenings).
And it was much easier to "fix" the grind on Boker GoBag.
I did all that by hand - manually. I own no machines or sharpening systems.
#600 diamond sharpener + diamond polishing paste and it's shaving sharp.
Pic of knives:
https://i.imgur.com/7qQ2jR6.jpg
I plan to do edge retention tests with them in the future too. I expect that Patriot will have better edge retention than GoBag.
So, expect "D2 vs D2" thread in the future.
Sorry for the long post, I hope you enjoyed to read
And grind...
Before:
After:
About the steel:
Pic of knives:
