Cutting anything will gradually degrade a 'shaving sharp' edge, no matter the steel. Some things more than others (such as the nylon rope, especially if it's dirty). Depending on the makeup of the 'poly tubing', that might dull the edge too (some types are very cut/abrasion-resistant).
That being said, it's possible & fairly common that a burr or wire edge might be the issue. After sharpening on a stone, sandpaper, etc., usually there will be at least a bit of a burr or 'wire edge' left. It's basically a very thin, fragile sliver of weakened steel at the very edge. It's possible that it'll cut OK for a short while, then it'll fold over to one side or the other. Then the edge becomes noticeably duller. Stropping the blade (using edge-trailing strokes) on leather, hard felt or other similar material should help to break off the burr or wire edge. Once that's done, edge retention will almost always be significantly better.
