I advise you to try it on before buying if you can.
Most their packs don't quite fit me. I'm just under 6', and Condor II and Falcon II are too short (the hip strap sits too high).
Never tried on the Vulture II.
Otherwise, all maxped gear I own is very well made.
A solution to the short Falcon II, is to add a Proteus to the bottom of it, so it takes some weight off your shoulders, as forum member daug came up with: http://www.bladeforums.com/forums/s...on-Falcon-II-Question?p=10041046#post10041046
I went this route, but didn't like the way it felt. Never had the Vulture 2, but I didn't care for the Falcon II. 15 lbs and it's not bad, but anymore than that it's not overly comfortable.
I have a Vulture II, and I've used it a fair bit for longer day walks when I need lots of kit (climbing gear, whatever) but nothing longer.
The biggest problem with the sack is the lack of a frame. It is of a size that, when loaded up, it really needs the support of an internal frame to transfer weight properly and stabilize the load.
Also, if you put a full 3 litre water bladder in the bladder sleeve, and load the sack up, the back of the sack gets pushed outwards and it feels like strapping on a barrel! I found it very uncomfortable like that.
I've made a few posts about it here, and the way I got around the problem was to insert a large, epicurean cutting board into the bladder sleeve. It alleviates the barrel problem (although it also makes it harder to fit the bladder in the sleeve at the same time) and it gives a little extra stability and stiffness to the sack. It's not ideal by any means, but the sack works better with the board than without it.
I really wish Maxpedition had put a proper back system into this sack, as otherwise it's close to ideal for a small 3-day sack. YMMV, of course.
It is a pretty big pack
I am about 90% set on buying a Maxpedition Vulture 2. Anyone here have experience with this pack ? Pos. or neg. experiences ? Looking for something that can take enough gear for a 4-5 day summer hike in some isolated Boreal.
Congrats on your bag selection.
I have a very similar bag (at least similar in size) and it's my EDC which means it carry's whatever photo gear i'm sporting for the day plus all my other essential outdoor items. All up it weighs 22lbs which isn't too bad imho. That doesn't include water or food so i'd need to figure in those extra lbs, but it carries very well.
I hope you enjoy getting your pack all set up!
If you're talking about being self supported for 4-5 days there are MUCH better packs out there for that mission. In addition to not having any sort of frame, the Maxpedition packs all have a plethora of unnecessary webbing, buckles, velcro, etc. That might serve a purpose for military deployments, but it's just extra, useless weight when you're on foot. Considering what else is available out there, a Maxpedition pack wouldn't be in my top ten list for even a long day hike.
There have to be twenty different brands of high quality backpacking/mountaineering packs, any of which will do a better job than the one you're looking at. They're lighter, better built, and will carry a load with much less discomfort, especially as the miles add up. And as others have said, fit is very important. Many of the better pack companies have a fitting schematic so you can measure key parts of your torso and determine which pack fits best.
I have three Maxpedition packs, and while I've found the quality to be pretty good, I'm not really all that impressed with them. A couple seams have failed and the majority of the molly webbing is more for looks than for useful attachment. I suppose my biggest beef is that the foam they use for padding shoulder straps is very low quality and deteriorates quickly. I have a Mountain
Smith pack that's 27 years old and the shoulder straps are rock solid, while my two-year-old Maxpedition gear slinger strap has turned to mush.
Kelty Redwing 50 works well and has a lot of useful features for a better price. Internal frame is almost a necessity if you have lower back issues. Just because you ordered does not mean you cant return it. but try it first without getting it dirty. Load it up and see how it feels in a test drive around the house. Better to learn if it works there than out on the trail, wil also allow you to fiddle with the adjustments.
Thanks. I have degenerative arthritis in the three lower vertebra just above my farticus maximus, motorcycle wrecks etc.
.......Sometimes the anticipation is equal to the objective.
As has been said
Maxepedition is not good backpacking gear
It is tough semi tactical
Basically you need a pack that transfers most of the weight to the hip via a good hip belt
I am not sure where you live
But are you near a backpacking store?
Get a good shop assistant to fit you with a good pack like a Kelty Redwing 50
It chinches down to be close your your back
Center of gravity high but thru your hips
Do not go above 50 lts your back will not take it
And I wouls suggest light sleeping bags more than heavier wool
Look for lighter gear and save weight for your back
