- Mar 1, 2022
Hey Guys, newish to the knife world, and was wondering, what stones or sharpening tools would be good for a Pm2 in Maxamet? Also, any ideas for compounds that could be used with a leather strop? Thanks.
Yep. I just touched up my Maxamet PM2 on Venev bench stones last night. About 10 minutes and it easily slices through paper towel now.Venev diamond bonded stones, all the way.
They eat my Maxamet knives for breakfast and you can get a hair-whittling edge on Maxamet with them, paired up with diamond loaded strops.
Whoa! Nice oneYep. I just touched up my Maxamet PM2 on Venev bench stones last night. About 10 minutes and it easily slices through paper towel now.
Since I got the R1 I decided I might as well go all in and splurged on a set of the 6" Venev Orion stones. Can't wait.
I am looking at the different grits, does it make a difference, and what would you recommend as starter diamond stones? thanks a lot.Venev diamond bonded stones, all the way.
Different grits for different purposes. For Venev's, the 240/400 + 800/1200 is an excellent basic setup for taking a knife from dull to a near mirror finish. But you'd want something courser if you're planning on reprofiling. The Venev 80/150 is out of stock in the bench stones, so an xtra course diamond plate would work well, or you could splurge on one of the CGSW course stones.I am looking at the different grits, does it make a difference, and what would you recommend as starter diamond stones? thanks a lot.
I'm looking at sharpening a dull knife, so what you gave me works, as for the edge, what compound would you recommend for a near-mirror finish?Different grits for different purposes. For Venev's, the 240/400 + 800/1200 is an excellent basic setup for taking a knife from dull to a near mirror finish. But you'd want something courser if you're planning on reprofiling. The Venev 80/150 is out of stock in the bench stones, so an xtra course diamond plate would work well, or you could splurge on one of the CGSW course stones.
For stropping compound, it just depends on how shiny you want the edge to be.
I think 1 micron would be a good choice if you only want to do one strop. Or if you do two, I'd go 1 and .5.I'm looking at sharpening a dull knife, so what you gave me works, as for the edge, what compound would you recommend for a near-mirror finish?
Are Maxamet blades prone to snapping, or is their fragility just potential chipping of the edge? I'll be honest and admit that I use my edc knife mostly for opening cardboard boxes, I'm just looking for a blade steel that will hold an edge without touching it up daily. Bought my first Spyderco a couple of weeks back, an Endura in K390, to see if my arthritic hands can open it easily; looks like a flipper works much better for me so I'm eyeing my next knife purchase.
You will have a better time with the compression lock, with arthritis. You should check out the lock if you have not before - see if it is right for you? It is a stronger, improved liner-lock, but "reversed". so that instead of putting your thumb down in front of the blade, you place it on a tab in back, when pushed, the blade falls safely into the handle. They make a device called the CME (compression made easy), a rubber doo-dad going over the compression tab to make it easier to close for left-handed people/arthritic people. You might not even need it, though.Are Maxamet blades prone to snapping, or is their fragility just potential chipping of the edge? I'll be honest and admit that I use my edc knife mostly for opening cardboard boxes, I'm just looking for a blade steel that will hold an edge without touching it up daily. Bought my first Spyderco a couple of weeks back, an Endura in K390, to see if my arthritic hands can open it easily; looks like a flipper works much better for me so I'm eyeing my next knife purchase.
Thanks for the info! I can open it one-handed, but it sometimes takes a bit of moving it around to get the right hand placement so I can get it open. Maybe some practice will remedy that, as well as break-in the knife.No, Maxamet blades are not prone to snapping. I wouldn't call a Maxamet edge "fragile." It holds up especially well to normal work, but if you go banging it into steel, staples, and rocks, you'll get some chipping. All steels will show some kind of damage if you go around doing crazy stuff with it.
In my opinion, K390 is preferable to Maxamet. It keeps a good edge longer, and the chipping I get is usually only visible under magnification. Is your Endura difficult to open two-handed? There's a bent spring that makes everything happen. It's not difficult to remove the spring, and then straighten it out a little in the vise. It will make the knife easier to open and the lock easier to disengage. The downside is that the blade has less bias to staying closed.
I see the 6 x 1in models on Amazon. Are there larger sizes, and a good company to buy them from? I'd rather not go through Amazon.Venev diamond bonded stones, all the way.
Yes, lots of different sizes available. Have a look on Gritomatic, they are a local US company in Georgia.I see the 6 x 1in models on Amazon. Are there larger sizes, and a good company to buy them from? I'd rather not go through Amazon.
