Write this in google , it is [PDF] ...............technical information - Norton AbrasivesThose speeds above will be for a specific belt - perhaps one of the ceramic belts for the steels. For the heat sensitive plastics I'd think it would be a different belt than for SS. Do you happen to remember which belts they were recommending?
The vast majority of sanding and grinding equipment runs well under certain conditions. For contact roll heads made of steel or rubber that is 80 durometer (Shore A scale), use 20 to 25 pounds of pressure per linear inch of belt width. For combination heads (contact roll with platen) and platen heads, use 15 to 20 lbs. of pressure per linear inch of belt width.
I don t think that I m missing anything .For now I have another power tool for grinding wood , micarta ......Natlek your missing something very important. Certain belts prefer that speed, but making a knife your gonna be grinding wood g10 micarta brass aluminum mild steel hardened steel epoxy fiberglass etc. But ask anyone in performance cars or bikes. Faster means more money replacing stuff more often, Subaru station wagon going 300,000 Miles you bet, Subaru wrx souped up? Not likely. You sure your home built tracking and drive wheels are rated at 10000 rpms? What about your bearings?
