MEC Gladerunner backpack
I recently picked up a new pack that I thought might interest some of you.
This is the Gladerunner from MEC. It comes in three sizes, short, standard and long. I got the long because it was the best fit for me. This puts the volume at 39 liters, or about 2400 cubic inches. The standard is 36 liters and the short is 33; there is also a pack called the Gladerunner TL, which is a little larger and has the same three short/standard/long options.
I bought this pack to use as both a ski pack, for which it was designed, and also as a sleek 3 day pack for fast long weekend outings during the summer. I believe it will make a good winter overnighter pack as well.
It’s not often that I’m taken enough with a pack to write a review of the thing. For instance, I have a Karrimor Sabre SF 60-100 that I really like a lot, and that is the best expedition pack I’ve personally owned. But I’ve never written a review of it. It’s a good pack but it didn’t blow me away with its design. It’s just a good pack.
But the Gladerunner is really something different and worthwhile. The first thing you notice about it is how narrow and flat it is. I have taken it skiing twice in the last two days, and it definitely does not interfere with poling in either a downhill/alpine ski or while cross-country skiing.
Whoops! Sorry, you interrupted me as I was being mesmerized by my mighty pecs. Anyway, you will notice that the pack is very narrow and fits tight to the body. The bottom black section is a heavy rubberized fabric that I am certain is waterproof, but also seems extremely wear resistant. The manufacturer calls this fabric “Hypalon,” which according to Wikipedia is a Dupont trademark for a synthetic rubber noted for its resistence to chemicals, temperature extremes and ultraviolet light, and which is a common fabric for folding boats. During some of the photo-taking, I spiked the bag into a snow drift to stand it up and then let it sit there for a while, but there was definitely no water leaking through the rubber.
In fact the entire bag seems pretty watertight. Living in Vancouver I am always nervous about describing anything as “waterproof” but when I came home from skiing last night I left a pile of snow to melt on top of the bag with a bunch of my stuff inside, and this morning, there was a puddle around the bag and water all over the top and around the main zipper, but nothing inside was wet at all. I would therefore be pretty confident that no large amount of water would make it inside during normal use. The fabric is 630 denier of something called “superpack” nylon, which although I know nothing about it, I do know that Arcteryx also uses it. I conclude on this basis that it probably kicks ass.
The next feature that I noticed was this zipper located at the apex of the shoulder straps.
Was it, as I first assumed, just the stowage compartment for a kydex framesheet of some sort as many daypacks have? Why no! Because there is no kydex framesheet. There is instead an aluminum perimeter frame – a bent rod that follows the outside edge of the pack. Not only does this make for an awesomely stiff pack, take note of the zipper when open:
Why get your straps wet in the snow when you can access the main pocket from the wrong side?
How cool is that!
Next up: the slim, stiff padding in the shoulder straps and waist belt. Unlike a lot of packs, which pad the hell out of their straps without actually improving the suspension system, these pads are thin and dense, making for a comfortable, firm suspension while reducing bulk. Here is a shot from the side of a shoulder strap, comparing it to my thumb. Note that the strap is about half the width of my thumbnail thick – the green is the front of the strap, the grey is the side.
The hip belt is the same dense, thin padding, with gear loops that I would be inclined to use either for ropes or possibly attaching a pulk sled for carrying larger loads in the snow. I guess this is the Nordic skier equivalent of toes-in-the-picture! I actually tried to keep my skis out of every picture but looks like I failed on that score.
Continuing on with exterior features, the sides of the pack sport a couple of compression straps which double as a harness for carrying skis or a snowboard. The snowboard would attach to the back, and although I haven’t tried it, I believe skis could be attached to the back in diagonal carry, or to the sides in low A-carry method. The A-method is my usual approach so I have not looked carefully at the diagonal on this pack, but I believe it could be done. On the back, the straps for skis or board are covered by that same Hypalon rubber so your skis won’t cut them up. The pack comes with a spare hypalon strap for the lower section of the ski/board harness, but I don’t have it installed in any of these pictures. It’s identical to the upper one, anyway.
Access to the pack is through the top, which closes with a substantial weather-resistant zipper that is tucked under a compression flap. That flap creates a flat, full-length pocket that runs almost the length of the pack, ending at the hypalon bottom section. In the above photo you can see three drain holes in the hypalon section in the center of the pocket.
A small zippered pocket and a hydration hose port are visible here as well.
When you open that compression flap, not only to you get access to the main compartment zipper, but there is also a small zippered pocket on the inside of the flap with a snap hook on the inside for keys etc. Even more importantly, there is also a fleece-lined pocket intended for goggles etc. Handy for sure!
Inside the main compartment is pretty standard; there is a mesh pocket which the manufacturer describes as for holding a snow study kit but I assume you are allowed to put other things in there as well. There are a couple of loops for keeping an avalanche probe and a shovel handle available at the sides of the main pouch, but less snow-specific users might be pleased to know that a Wetterlings large hunter’s axe – that’s the 19” handled one – fits as though they were meant to hold nothing else as well.
Overall, this is an absolute gem of a pack that is ideal for snow sports enthusiasts but would also make a great pack for fast hikes. Weight is listed on the website as 1.9 kg for the long model, or about 4 pounds, but I think that estimate is on the high side. I don’t have the equipment to accurately weigh this pack, but I would be surprised if it actually weighs four pounds. It feels more like about three to me.
The last thing I can comment on is the colour. As you can see in these photos, the pack is a very unobtrusive green/slate/beige combo that blends well with a natural palette. If you care about this sort of thing, it is an almost camouflage pack with a completely civilian, non-threatening appearance. If you are looking for something that will blend well if you need it to, but won’t attract attention in an urban or populated setting, this is a great pack. It also comes in black, which is great for people who don’t care about blending in to natural environments and is also good for ninjas.
Overall I am really impressed with this piece of gear. I really rarely comment on the gear that I use because it is so often basically interchangeable to me – I am not often particularly taken with one fleece over another, or one pack over another, or even one knife over another! As I have often said, I love my Aurora but I know perfectly well that my Mora #2s will do every knife task I need done and then some.
But this is a special case in which I’ve encountered a pack that has been designed to perform in a particular way, and not only achieves the goals of the designer but exceeds my expectations. Granted, I have not spent a year beating on this thing and so I can’t comment with absolute certainty on its durability – although I suspect it will hold up very well after a good look at the stitching and materials. But the design is great and I would recommend this pack to anyone looking for a mid-size pack either for overnighters in the snow or short trips up to about 3 days in length in better weather.
Finally, the nitty gritty:
This pack is made by Mountain Equipment Co-op, a Canadian chain similar to REI.
Their house brand stuff is generally quite reliable and solid, and I have never had a problem with warranty work or replacement on anything they sell, although I have not had much need for their warranties, either, as practically nothing they’ve sold me has broken and nothing at all that they built themselves.
Most incredibly, I picked this pack up for $69 Canadian. They are blowing out these packs, and the larger Gladerunner TLs, for $69 and $79, marked down from $113 and $120, respectively. Two thumbs way, way up for this pack.
Hope this is useful to someone;
Geordie
Hmmm. How much stuff can (have) you put inside? I am shopping for a new pack, but it has to be reasonably priced (I have car issues), tough as nails, and readily available (not on backorder all the time). Whatcha think?
Well, when these pics were taken I had a -12c (~10 farenheit) down bag, spare clothing and a siltarp + some food and gear...could have easily done an overnighter for sure with what I happened to have on me there.
But the amount of space you need depends a lot on you. The best thing I can tell you is that 39l liters or 2400 cubic inches is what I would consider a 1-2 day winter pack or a 2-3 day summer pack. But you should probably have a look at packs in that size before you decide. Remember that there is also the Gladerunner TL, which is a little larger.
This is certainly readily available NOW, but I doubt it will last at this price.
Hope this helps,
Geordie
Also Spooky they may ship to the US via their internet site! I do have a lot of American friends with MEC gear!
Great review. I have an older expedition (60 L) MEC pack. Great bag. Their in-house stuff is always great performance/value and solidly built. That little pack does look very nice!
that is a pretty cool pack.. i like it...:thumbup: looks nice and streamlined...
freggin sweet man, I like that pack alot, the only thing I have problems with is once I get a bigger pack, I allways bringin more gear than I need, thats why I have to limit pack size, I wouldn't take any thing else except my lunada and a tent now, just to keep things good for me..... I suck:D
There does seem a lot to like about that pack. Neat write up too.
Just for your files - Remember the old Gerber Big MF and LMF. The handles of those were done in compressed Hypalon. I think it is used for some fishing rod handles too.
The solid flotation platforms of my modern snowshoes are made of Hypalon.
Great review... I am a huge fan of MEC, there stuff is really high quality and they have a fantastic warranty (an aside... I've only ever returned on thing to them, a pair of Italian made Zamberlan hiking boots, I had them for two years and on the last job they were used on in Norway they started leaking, further inspection revealed countless perforations through the vibram soles as though I had been walking on nails, which of course I hadn't. I returned this beat up pair of smelly swampy boots to them at MEC, they gave me a brand new, more expensive pair of boots no questions asked, said it was probably a bad batch of vibram).
I have had one of their medium sized packs I have been using in the field for close to 18 years, I beat that thing up as best I could, hauling rocks in it, soil samples, you name it, I finally retired it last year, and only because the nylon was starting to delaminate from the inside coating, probably due to the sun (the aluminium stay saved me one time in the jungle in Venezuela, my driver locked the keys in the Landcruiser hours from civilisation, I used the file on my Leatherman to file a slot into the aluminium and "jimmied" the lock open, saved us from having to smash the window).
I also have one of their large 100 litre North Twin packs, I've had it for almost the same amount of time and it's been on hiking trips with me all over the world, very comfortable, and very reasonably priced.
Overall two thumbs up for MEC :thumbup::thumbup:
I have a MEC brio 30L (no longer listed on the website) I EDC this pack with all of the random crap that I need from time to time, and never a problem. I also have one of the bigger (70L I think) Brio packs, heavier than most of the higher dollar stuff, but pretty much indestructible. I have the Transit 4 sholder bag as a medkit, and it works great on the bench or sidelines, and I can wear it under a backpack to keep needed items quickly at hand.
