I've finished moving into my new house (no more apartment living for me!) and I am no longer restricted to using the kitchen table as a work bench. As such it is time to come up with a standardized method to measure sharpness and cutting ability.
I would like your ideas on how best to measure force application in various modes.
My mettler 510g balance (.001g readability) is only suitable for lightweight jigs. My main concern in using thread is the required weight of the apparatus in order to obtain suitable and repeatable tension. What have you guys rigged up?
If using a method where the thread is applied to edge (whereas the method above would be applying the edge to the thread) the limit on maximum weight is placed on the knife and whatever holder is required to keep it upright on the pan. In this instance the weighted thread would be lowered onto the edge by hand.
Am I going about it all wrong? What approach has worked best for you?
Measuring cutting ability will be a bit trickier and will likely require a scale I don't currently own, any thoughts on that?
